Whmcs 5.3.4 ออกแล้วครับ / 5.3.5 ตามมาแล้วครับ
WHMCS 5.3.4 ออกแล้วครับ แก้บั๊กมากมายทีเดียว
UPDATED: WHMCS 5.3.5 ออกตามมาแล้วครับ
WHMCS 5.3.4 is now available to download.
This release contains scheduled maintenance improvements and other fixes for the 5.3 series.
For a full list of changes, please refer to the changelog @ Changelog:WHMCS V5.3 - WHMCS Documentation
You may download either an incremental patch set (only for 5.3.3 upgrades) or the full file version (valid for upgrading any previous version or for new installs) via our Downloads Page.
Download: http://download.whmcs.com/
Changelog: Changelog:WHMCS V5.3 - WHMCS Documentation
Release Notes: Version 5.3 Release Notes - WHMCS Documentation
Changelog:
Version 5.3.4
Release Type: MAINTENANCE
Release Date: 18th February 2014
General
Case #2932 - Remove leading zero from phone numbers passed to domain registrars
Case #3048 - Add Logging of Admin Client Profile Custom Field Changes
Case #3240 - Make presence of attachments known in admin ticket notifications
Case #3252 - Displays the correct error message after a domain sync cURL failure
Case #3328 - Support Tickets: Add option to only update last reply timestamp on change of status
Case #3333 - Delete custom field entries for a product when the order is deleted
Case #3513 - Assert proper token values for query retrieval
Case #3513 - Prevent ‘action’ parameter from being squashed by ajax call
Case #3594 - Improve Logging of Overdue Notice disabling in Admin Client Profile
Case #3773 - Remove single and double quotes from hyperlinks in tickets
Case #3792 - Add exception catch and logging for failed admin emails & notifications
Case #3917 - Log Ticket Escalation Rule execution to ticket log
Case #3939 - Admin sidebar updated to link to product types work with new param key
Case #3940 - Pipe character in config options not being handled correctly in upgrades
Case #3951 - Run the ServiceDelete hook when deleting services via client summary page
Case #3962 - Fix Configurable Options not showing in Bundle Config
Case #3966 - Tidy Twitter response prior to parsing to prevent warnings
Case #3986 - EU VAT Addon: Fix sequential numbering via mass pay
Case #3988 - Improve logic for determining TLDs to search when none specified
Case #3989 - API: Add create as admin option flag to OpenTicket Command
Case #3993 - Preserve custom field values when changing department
Case #4007 - Revert PDF Font override behaviour
Case #4013 - Forces UTF-8 encoding on the Twitter link feed
Case #4016 - Pulls gateway variables into scope for third party gateways
Case #4016 - Removes a redundant merge on an array when grabbing gateway parameters
Case #4017 - Added support for Test Connection ability to modules
Case #4017 - Added Test Connection ability to Plesk Module
Case #4017 - Added Test Connection ability to cPanel Module
Case #4017 - cPanel Module: Improve error message response when SSL is enforced
Case #4021 - Fix TLD specific fields not displaying on some order forms
Case #4023 - Fix Invalid Token error in Project Management Client Association
Case #4023 - Fix due days calc in Project Management Addon after editing a project
Case #4024 - Fix order confirmation page showing payment required for free bundles
Case #4026 - Fix Message Preview in admin send message not interpreting HTML
Case #4030 - Fix Usage Statistics importing from server modules
Case #4033 - Fix Invalid Token error on admin homepage actions
Case #4034 - Remove case-sensitivity from localAPI commands
Case #4036 - Fix Admin Advanced Search by Orders redirecting to wrong page
Case #4037 - Restore freesans fonts that were removed as part of TCPDF upgrade
Case #4038 - Prevent matching conflicts with TLD additional fields
Case #4043 - Only prefix TLD with a dot in Domain Checker if not present
Case #4044 - Add Windows OS logic condition in file path validation
Case #4047 - Resolve encoding issues with plain text emails
Case #4051 - Fix some activity log keywords not auto converting to links
Case #4052 - Fix broken include path of whois functions file when IDN
Case #4053 - Fix fatal error from bad func_get_args use
Case #4054 - Fix Invalid Token error when enabling or disabling ID protection
Case #4055 - Add an admin setting for Mail Encoding
Case #4055 - Change default email encoding to 8bit
Case #4056 - Fix pricing grid background color in IE 11
Case #4059 - Add an admin setting for Hook Debugging
Case #4061 - Fix incorrect variable call in Worldpay Futurepay callback
Case #4062 - Fix starting price calculations for cycles greater than monthly
Case #4063 - Fix invalid redirect in upgrade process
Case #4065 - Improve logic of starting price calculations in cart
Case #4072 - Place IDNA class in PRS-0 compliant heirarchy
Case #4075 - Add an Admin Setting for PDF Paper Size
Case #4076 - Add Item Status filter to Client Summary Page
Case #4080 - Update default fonts available for PDF Generation
Case #4084 - Fix double encoding of domain registrar config values
Case #4085 - iDeal via Mollie: Fix error when no custom description is set
Case #4088 - Enom New TLDs Addon: Restore dynamic template vars
WHMCS 5.3.5 is now available to download.
This update addresses 4 specific issues identified following the 5.3.4 release.
You may download either an incremental patch set (only for 5.3.4 upgrades) or the full file version (valid for upgrading any previous version or for new installs) via our Downloads Page.
Note to 5.3.3 Users
If you are running Version 5.3.3 currently, and do not wish to use the full version to upgrade, then you can apply the 5.3.4 incremental patch set followed by the 5.3.5 incremental patch set. Both of these are made available via the Downloads page.
IMPORTANT: For each incremental patch set you wish to apply, remember to visit the Admin area and confirm the appropriate version number is displayed before applying a subsequent incremental patch set.
Case #4099 - Remove object reference outside of object within client area
Case #4109 - ResellerClub: Fix fatal error occurring in contact creation
Case #4115 - Trigger error when handling unspecified Exceptions in PHP < 5.3.6
Case #4116 - Fix domain registration & management problems (Enom/ResellerClub)
ยังไม่กล้าอัพเลย - -’’ เห็นรอบก่อนบั๊คกันเพียบ
เจอ bug กับ resellerclub เวลาแก้ไข nameserver ครับ โหลดตัวนี้ไปทับแล้วก็เหมือนเดิม http://forum.whmcs.com/showthread.php?85762-Case-4109-5-3-4-ResellerClub-Registration-Fix
ถ้าใช้ 5.3.3 อยู่แล้วก็อัพเป็นตัวนี้เลยครับ เพราะแก้บั๊กของ 5.3.3 เยอะเหมือนกัน
แต่ถ้าใช้ 5.2 อยู่ ก็ยังไม่ต้องอัพก็ได้
ออกบ่อยเกิน อัพไม่ทันครับ
เดี๋ยวขอลองอัพดู ก่อนนะครับ
อัพเรียบร้อยครับ :d5f02ecd:
ดูเหมือน โหลดไปทับแล้วแต่ก็ยังแก้ ns ไม่ได้นะครับใครยังไม่อัพรอก่อนดีกว่า ผมอัพแล้ว ทับแล้วลูกค้าแก้ไม่ได้
ปล.ลองเอาตัวเก่ามาทับดูแก้ได้อยู่นะครับแต่ไม่รู้ว่ามันจะเวิร์คมั้ย
ดูเหมือนว่า Hotfix ที่ออกมาก่อนหน้านี้จะแก้ไขปัญหา ResellerClub ไม่ได้
เช็คล่าสุดพบว่ามีตัวใหม่ออกมานะครับ เห็นในไฟล์มีไฟล์ของ ResellerClub ถูกรวมไว้ด้วย ใครใช้ ResellerClub ลองดูหน่อยแล้วกันครับ
Case 4116 - Doman Registration FixSteps to Apply: Upload the files as set out within the zip folder to your root WHMCS directory
Download Link: http://www.whmcs.com/download/582/domains-reg-fix
ก็ยังเหมือนเดิม ตอนนี้เอาไฟล์ของ 5.3.3 แก้ขัดไปก่อนครับ
5.3.5 ออกมาแล้วครับ http://blog.whmcs.com/?t=85887 ตอนนี้ resellerclub สามารถแก้ nameserver ได้แล้วครับ
ออกแทบจะรายวัน :th_085_:
อัพแล้วครับ ใช้งานได้ปกติแล้ว แก้ NS ของ RC :d16c4689:
อัพตามแล้วครับ
