[h=1][FONT=inherit]Version 5.3.11[/FONT][/h]
[LIST]
[]Release Type: MAINTENANCE
[]Release Date: 17th December 2014
[/LIST]
[h=2][FONT=inherit]Maintenance[/FONT][/h][COLOR=#444444][FONT=Open Sans]Case #2536 - Stop enter key disabling rich text editor while editing a KB article
Case #2731 - Fix Password Strength layout issue in Portal theme
Case #2804 - Allow mass ticket actions to be performed for selections accross multiple categories
Case #2877 - Prevent duplicate email addresses in CC recipients of tickets
Case #2936 - Refine wording of Email Sending Completed
Case #2986 - Hide Nameservers tab when not available (in Default template)
Case #3005 - Fix configurable options not showing defaults for some options
Case #3555 - Fix currency formatting not being applied in printable quote
Case #3803 - Re-add clientgroupcolour variable to admin ticket view
Case #4003 - Hide required message on domain select in ajax cart template
Case #4124 - Replace invalid text instructions in PDF Batch Export
Case #4127 - Force Overdue text to display in System Overdue widget when 0 overdue
Case #4217 - Stop default nameservers overriding client defined on order
Case #4224 - Correct missing tabIndex on States dropdown
Case #4244 - Simplify UX when applying custom date filters to the transaction list
Case #4464 - Display error message on order form when domain fails to validate
Case #4518 - Use reply-to address from incoming emails when present
Case #4526 - Honor invoice increment value on duplication
Case #4551 - Allow products to be removed from the ajax cart in any order
Case #4674 - Fix printable quote view not showing tax breakdown
Case #4676 - Fix calculation of client due invoices email template merge field
Case #4688 - Require email address when adding a contact via admin area
Case #4869 - Refresh custom fields in admin ticket view upon department change
Case #5003 - Ensure current credit card details are always used post update
Case #5038 - Remove no longer available free email checker link from admin area
Case #5059 - Improve Two-Factor Auth styling in client area themes
Case #5110 - Correct account count display on Domain Resolver Utility Tool
Case #5131 - Ensure bundle errors show in Ajax Cart Order Form Template
Case #5144 - Ensure admin quote download filename uses translated quote name
Case #5150 - Update and add new South African gTLD whois servers
Case #5155 - Update whois servers for Lithuanian domain names
Case #5170 - Add missing field name on admin Quotes when Client Dropdown disabled
Case #5197 - Restore access to the admin folder in Windows
Case #5208 - Update EU whois server match string
Case #5225 - Fix Cart Summary not updating when no domain or configurable options present
Case #5282 - Update whois server for .KIM TLD
Case #5359 - Add additional parameters to ShoppingCartValidateCheckout hook
Case #5362 - Send admin failed login attempt email notices for whitelisted IP addresses
Case #5376 - Correct spelling of Recepient to Recipient
Case #5379 - Add whois server for .SCOT
Case #5398 - Update whois server for .CO.ZW
Case #5402 - Make it possible to override params in PreModule* Hooks again
Case #5416 - Correct display currency on Bulk Pricing Updater when default not used
Case #5431 - Fix duplicate invoice process omitting tax rate 1 info
Case #5451 - Add .NZ to whois server definitions
Case #5456 - Update whois server definition for the .MODA tld
Case #5460 - Ensure Contact shows on getTickets via the API where applicable
Case #5517 - Remove all support for vendor-required SSLv3[/FONT][/COLOR]
[h=2][FONT=inherit]Modules[/FONT][/h][COLOR=#444444][FONT=Open Sans]Case #2743 - eNom New TLD’s - Improve Logging
Case #2777 - Direct Debit - Add multi-language support
Case #2986 - Email Registrar: Add support for nameserver change submissions
Case #3282 - ResellerClub: Add new .tel additional domain field parameters
Case #4196 - Google Analytics: Add support for new Universal Analytics protocol
Case #4212 - HyperVM: Update to not continuously append hostname on create
Case #4445 - 2CheckOut: Ensure over-payments are applied to credit
Case #4616 - PSIGate - Update module to use new port for better SSLv3 support
Case #4944 - Register.com - Nameserver change incorrectly shows success as failure
Case #4974 - OpenSRS - Add support for .pro registrations
Case #5007 - MaxMind: Remove reference to them in fraud check failed messaging
Case #5011 - OpenSRS: Add missing API parameter to use supplied Tech Contact
Case #5043 - eNom: Use correct field for .AU registrant ID information
Case #5061 - Licensing Addon - Clarify usage comments in sample check code
Case #5087 - Licensing Addon - Update sample code to validate HTTP response code
Case #5140 - Project Management Addon: Correct SQL Error occuring in client area
Case #5183 - PayPal Pro: Add support for additional currencies to 3D Secure
Case #5321 - OpenSRS - Fix error when ABN was selected for eligibility type
Case #5326 - HeartInternet - Send additional API parameters to allow ordering more TLDs
Case #5347 - GlobalSign - Force SHA-256 Hashing Algorithm for SSL Purchases
Case #5450 - ResellerClub: Auto create SSL email template when required
Case #5469 - eNom: Add support for registering the .QUEBEC TLD[/FONT][/COLOR]
[h=2][FONT=inherit]API[/FONT][/h][COLOR=#444444][FONT=Open Sans]Case #2790 - AddClientNote: Fix double line spacing when adding a note
Case #3724 - GetInvoices: Return correct currency when no userid supplied
Case #4226 - Stop undefined messages occurring when errors enabled
Case #5283 - Multiple: Resolve error when attempting to send invoice related emails[/FONT][/COLOR]
[h=2][FONT=inherit]Language[/FONT][/h][COLOR=#444444][FONT=Open Sans]Case #2644 - Consolidate language file definitions
Case #4247 - Update Farsi Language file with additional translations
Case #4255 - Remove duplicate language definitions in Project Management Addon
Case #5247 - Added additional Dutch translations admin and client side[/FONT][/COLOR]
