Warning: copy() [function.copy]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/nokia/:/tmp:/usr/local/lib/php/) in /home/nokia/domains/nokia-connect.com/public_html/nokia-backoffice/upload_s.php on line 14
Error.. can't copy
Warning: unlink() [function.unlink]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/nokia/:/tmp:/usr/local/lib/php/) in /home/nokia/domains/nokia-connect.com/public_html/nokia-backoffice/upload_s.php on line 22
$dir = getcwd()."/../banner/small/";
;$dir = getcwd()."s";
if($UploadedFile != none)
print("Local File : $UploadedFile
print("Name: $UploadedFile_name
print("Size: $UploadedFile_size
print("Type: $UploadedFile_type
print("<hr>");
if(copy($UploadedFile, "$dir/$UploadedFile_name"))
print("$UploadedFile has been copy to $path/$UploadedFile_name
else
print("Error.. can't copy
unlink($UploadedFile);
else
print("Error.. no file.
มัน error อ่ะครับ รบกวนด้วยน่ะครับ ผมไม่ได้เขียนเอง แต่ลูกค้าเขียน
Linux , DA น่ะครับ
แถม PHP Info ให้ด้วย http://www.nokia-connect.com/nokia-backoffice/info.php
