เอาเป็นว่า มีคนส่งเมลมาตามนี้น่ะค่ะ กำลังตามไปศึกษา ใครมีอะไรมาเติม รบกวนเพิ่มด้วยค่ะ
Hey Moui,
In the past month, thousands of private SQL Injections and XSS attacks caused websites to get hacked, and databases stolen. Having to keep up with patches for the software you use can be hard, and even being 12 hours late to install it could be to late.
Finally, there is a solution which can keep your website safe from all types of web attacks, even if the attack is private.
http://www.firewallscript.com is the worlds first PHP based Firewall Script. It can stop all types of SQL Injections, XSS, PHP Injections, Directory Transverals, Null Bytes, etc… - By installing FirewallScript, You can keep your site safe from attacks, even if you miss a patch!
http://firewallscript.com/features.htm Check out the features it can add to -ANY- PHP script. Another benefit of FirewallScript is it can run on shared hosting, or hosting where you have no direct server access. All you need is the ability to upload files.
