Reuse Code Or Code It Yourself?
eldavojohn writes "I began coding for a project that had simple requirements for my employer — Web services and a test application for them. But requirements have been creeping, as they always do. Initially I had decided to use the Spring Framework with Hibernate. And I re-used a lot of libraries that made things simple and quick for me. The new requests coming in involve capabilities beyond those of the frameworks. Now, I used to be told that good programmers write code and great programmers reuse code. It’s starting to look like I would have saved myself a whole lot of time if I had written the database transaction using JDBC instead of Hibernate — now that I’m married to this object model framework, some of this stuff doesn’t look doable. So what is better for the majority of software projects out there: reuse code, or code from scratch? What elements or characteristics of a problem point to one option over the other?"Read more of this story at Slashdot.
