สอบถามผู้รู้เกี่ยวกับการ จูน my.cnf หน่อยคับ
นานๆทีจะขึ้นแบบนี้คับ
Lost connection to MySQL server at ‘reading initial communication packet’, system error: 0
แล้วอาการก็จะหน่วงๆ แล้ว load average ก็จะขึ้นสูงประมาณ 100 แล้วก็จะลงมาต่ำเหมือนเดิม
เครือ่งเป็น dell r210 ram 16 GB
เรียนท่านเทพช่วยแจงหรือปรับ หรือ my.cnf ตัวที่ปรับมาแล้วหรืออะไรอย่างงี้ก็ได้คับ
อันนี้เป็น my.cnf ของผมคับ
The MySQL database server configuration file.
You can copy this to one of:
- “/etc/mysql/my.cnf” to set global options,
- “~/.my.cnf” to set user-specific options.
One can use all long options that the program supports.
Run program with --help to get a list of available options and with
–print-defaults to see which it would actually understand and use.
For explanations see
http://dev.mysql.com/doc/mysql/en/server-system-variables.html
This will be passed to all mysql clients
It has been reported that passwords should be enclosed with ticks/quotes
escpecially if they contain “#” chars…
Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
Here is entries for some specific programs
The following values assume you have at least 32M ram
This was formally known as [safe_mysqld]. Both versions are currently parsed.
#[mysqld_safe]
#socket = /var/run/mysqld/mysqld.sock
#nice = 0
[mysqld]
* Basic Settings
* IMPORTANT
If you make changes to these settings and your system uses apparmor, you may
also need to also adjust /etc/apparmor.d/usr.sbin.mysqld.
user = mysql
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
skip-external-locking
skip-name-resolve
Instead of skip-networking the default is now to listen only on
localhost which is more compatible and is not less secure.
#bind-address = 127.0.0.1
#bind-address = 192.168.250.2
bind-address = 0.0.0.0
#bind-address = localhost
#–skip-networking
* Fine Tuning
key_buffer = 8048M
max_allowed_packet = 256M
thread_stack = 128K
thread_cache_size = 256
myisam-recover = BACKUP
query_cache_limit = 256M
query_cache_size = 128M
#log_error = /var/log/mysql/error.log
Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time =
log-queries-not-using-indexes
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 1
max_binlog_size = 64M
max_connections = 150000
max_connect_errors = 10000
max_allowed_packet = 64M
table_cache = 500000
sort_buffer_size = 3024M
read_buffer_size = 256M
read_rnd_buffer_size = 3524M
myisam_sort_buffer_size = 3524M
thread_cache = 92
thread_concurrency = 256
default-character-set=utf8
max_tmp_tables = 400
tmp_table_size= 3024M
concurrent_insert=4
low_priority_updates=1
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
* InnoDB
InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
Read the manual for more InnoDB related options. There are many!
* Security Features
Read the manual, too, if you want chroot!
chroot = /var/lib/mysql/
For generating SSL certificates I recommend the OpenSSL GUI “tinyca”.
ssl-ca=/etc/mysql/cacert.pem
ssl-cert=/etc/mysql/server-cert.pem
ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
max_allowed_packet = 128M
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
#[isamchk]
#key_buffer = 512M
#sort_buffer_size = 256M
#read_buffer = 556M
#write_buffer = 556M
#[myisamchk]
#key_buffer = 512M
#sort_buffer_size = 1024M
#read_buffer = 1024M
#write_buffer = 128M
* IMPORTANT: Additional settings that can override those from this file!
The files must end with ‘.cnf’, otherwise they’ll be ignored.
!includedir /etc/mysql/conf.d/
ใส่อะไรเวอร์เกินขนาดนี้ครับ
thread_cache = 92
แล้วมันต้องใส่ยังไงคับผมก็ปรับมั่วๆ อ่ะคับอ่านนู่นอ่านนี่
ลองไม่ใส่ดูก่อนดิครับ อาจจะดีกว่าก็ได้ แล้ว ส่วนไหน อืด ค่อยเพิ่มเอา
ผมไม่รู้ว่าค่าเริ่มต้นมันคืออะไรอ่ะคับ ปรับจนมั่วหมดแล้วคับ
https://raw.github.com/major/MySQLTuner-perl/master/mysqltuner.pl
key_buffer = 2048M
max_connections = 500
table_cache = 8192
sort_buffer_size = 4M
read_buffer_size = 2M
read_rnd_buffer_size = 4M
myisam_sort_buffer_size = 64M
tmp_table_size= 512M
ปรับเหลือแค่นี้พอครับ
ตามที่คุณตั้ง เครื่อง database คุณต้องมีแรมประมาณหลักหลายร้อย TB โน่นแหละครับถึงจะใช้งานได้ - -’
ถ้าเครื่องแรม 8GB หละฮ่ะ
share hosting แรมไม่เกิน 8GB
[mysqld]local-infile=0
#skip-innodb
innodb_buffer_pool_size=256M
#innodb_additional_mem_pool_size=4M
innodb_log_buffer_size=2M
innodb_flush_log_at_trx_commit = 1
innodb_thread_concurrency=2
#innodb_log_file_size = 256M
innodb_file_per_table
[COLOR=#000000][FONT=Tahoma]skip-character-set-client-handshake
skip-name-resolve
max_connections = 300
key_buffer = 512M
myisam_sort_buffer_size = 32M
join_buffer_size = 1M
read_buffer_size = 1M
sort_buffer_size = 2M
read_rnd_buffer_size = 1M
table_cache = 1536
thread_cache = 4
wait_timeout = 3600
connect_timeout = 10
max_tmp_tables = 256
tmp_table_size = 128M
max_allowed_packet = 16M
query_cache_limit = 1M
query_cache_size = 32M
query_cache_type = 1
query_prealloc_size = 16384
query_alloc_block_size = 16384
max_heap_table_size = 128M
#tmpdir=/var/mysqltmp
log_warnings=0
[mysqld_safe]
log-error=/var/log/mysqld.log
pid-file=/var/run/mysqld/mysqld.pid
open_files_limit = 16384
[/FONT][/COLOR]
ถ้าเครื่องเดี่ยว RAM 16GB หล่ะครับ
ตามกระทู็ ก็ Ram 16GB นะครับ ลองไล่อ่าน comment ดูครับ
อ๋อโทษทีครับ พอดีผมไปอ่านตรง RAM 8GB หน่ะครับ
แรม 16GB ผมยังใช้ค่าพวกนี้อยู่เลย (ฮา) ปรับขึ้นแค่ inno buffer pool กับ key buffer อะครับ
ถ้า share host ใส่ max_user_connections ไว้ด้วยก็ดี เวลาตายให้มันตายเป็นเว็บๆไป ไม่ลากจนเต็มทั้งเครื่อง
max_user_connections=100
มาซุ่มเก็บข้อมูลครับ ^-^
