ขาย IBM ServeRAID 5014M 4,000 [chipset] LSI-MegaRAID 9260-8i
[B]ขาย IBM ServeRAID 5014M 4,000 [/B][chipset] LSI-MegaRAID 9260-8i
ของอยู่ CAT-SiamdataIDC ครับ
เบอร์โทรครับ 081-5922166
ขายเนื่องจากซื้อมาใส่ cisco c22 แล้วใช้ไม่ได้ครับ แต่ถ้า PC ธรรมดาน่าจะได้ทุกเครื่อง
[B]Specifications
The ServeRAID M5015 and ServeRAID M5014 adapter cards have the following specifications:
[LIST]
[]Eight internal 6 Gbps SAS/SATA ports
]Two Mini-SAS internal connectors (SFF-8087)
[]6 Gbps throughput per port
]800 MHz PowerPC processor with LSI SAS2108 6 Gbps RAID on Chip (ROC) controller
[]x8 PCI Express 2.0 host interface
]Onboard data cache (DDR2 running at 800 MHz):
[LIST]
[]ServeRAID M5015: 512 MB
]ServeRAID M5014: 256 MB
[/LIST]
[*]Intelligent Li-Ion-based battery backup unit with up to 48 hours of data retention:
[LIST]
[]ServeRAID M5015: Standard in the option part number
]ServeRAID M5014: Optional
[/LIST]
[]Supports RAID levels 0, 1, 5, 10, and 50 (RAID 6 and 60 support with the optional M5000 Advanced Feature Key)
]Connects to up to 32 SAS or SATA drives
[]SAS and SATA drives are supported, but the mixing of SAS and SATA in the same RAID array is not supported
]Supports up to 64 logical volumes
[]Supports LUN sizes up to 64 TB
]Configurable stripe size up to 1 MB
[]Compliant with Disk Data Format (DDF) configuration on disk (COD)
]S.M.A.R.T. support
[/LIST]
[/B]
check PM ครับ
ตอบแล้วครับ
