[root@wwww ~]# #dd if=/dev/zero of=/dev/sdb bs=512 count=100
[root@wwww ~]# fidsk -l
-bash: fidsk: command not found
[root@wwww ~]# fdisk -l
Disk /dev/sda: 320.0 GB, 320071851520 bytes
255 heads, 63 sectors/track, 38913 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 13 104391 83 Linux
/dev/sda2 14 38913 312464250 8e Linux LVM
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
/dev/sdb1 1 121601 976760001 83 Linux
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
/dev/sdc1 * 1 121601 976760001 7 HPFS/NTFS
Disk /dev/sdd: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
/dev/sdd1 1 182401 1465136001 83 Linux
Disk /dev/sde: 998.9 GB, 998999326720 bytes
255 heads, 63 sectors/track, 121454 cylinders
/dev/sde1 1 121454 975579223+ 83 Linux
Disk /dev/sdf: 998.9 GB, 998999326720 bytes
/dev/sdf1 * 1 121601 976760001 83 Linux
Disk /dev/sdg: 998.9 GB, 998999326720 bytes
/dev/sdg1 * 1 121601 976760001 83 Linux
Disk /dev/sdh: 998.9 GB, 998999326720 bytes
/dev/sdh1 * 1 121601 976760001 83 Linux
Disk /dev/sdi: 998.9 GB, 998999326720 bytes
81 heads, 63 sectors/track, 382357 cylinders
Units = cylinders of 5103 * 512 = 2612736 bytes
/dev/sdi1 1 382819 976761560 83 Linux
Disk /dev/sdj: 998.9 GB, 998999326720 bytes
/dev/sdj1 1 382819 976761560 83 Linux
Disk /dev/sdk: 998.9 GB, 998999326720 bytes
/dev/sdk1 1 121454 975579223+ 83 Linux
[root@wwww ~]#
ครับ ยังไงต่อหรอครับ
