User ic2ykun9 created[/CENTER][/TD]
[/TR]
[TR]
[TD][TABLE=“width: 50%”]
[TR]
[TD=“bgcolor: #C0C0C0”][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][CENTER][B]Details[/B][B]Unix User created successfully
User’s System Quotas set
[B]Error with system Quotas
setquota: Mountpoint (or device) /var not found or has no quota enabled. setquota: Not all specified mountpoints are using quota. Debug Guide
User’s data directory created successfully
Domains directory created successfully
Domains directory created successfully in user’s home
User added to ssh config file.
Reseller’s package directory created successfully
Reseller created
Admin created
./data/admin/r_welcome.txt already exists, not overwriting[/B][/B][/CENTER][/TD]
[/TR]
[/TABLE]
/dev/sda2 on / type ext4 (rw,usrquota,grpquota)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
tmpfs on /dev/shm type tmpfs (rw,noexec,nosuid)
/dev/sda1 on /boot type ext4 (rw)
/dev/sda5 on /home type ext4 (rw,nosuid,usrquota,grpquota)
/dev/sda3 on /tmp type ext4 (rw,noexec,nosuid,loop=/dev/loop0)
/dev/sdb2 on /var type ext4 (rw)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
ผมไปเพิ่ม extra_quota ใน DA ใส่ค่าไปมี mount / และ /var
