สร้าง Dropbox ผ่าน BitTorrent
BitTorrent ไม่ใช่แค่เอาไว้โหลดหนังอีกต่อไป ล่าสุด BitTorrent Inc ออกซอฟท์แวร์สำหรับ Sync Folder ผ่าน P2P network ซึ่งใช้งานง่ายมาก
BitTorrent today released folder syncing software that replicates files across multiple computers using the same peer-to-peer file sharing technology that powers BitTorrent clients.
The free BitTorrent Sync application is labeled as being in the alpha stage, so it’s not necessarily ready for prime-time, but it is publicly available for download and working as advertised on my home network.
BitTorrent, Inc. (yes, there is a legitimate company behind BitTorrent) took to its blog to announce the move from a pre-alpha, private program to the publicly available alpha. Additions since the private alpha include one-way synchronization, one-time secrets for sharing files with a friend or colleague, and the ability to exclude specific files and directories.
BitTorrent Sync provides “unlimited, secure file-syncing,” the company said. “You can use it for remote backup. Or, you can use it to transfer large folders of personal media between users and machines; editors and collaborators. It’s simple. It’s free. It’s the awesome power of P2P, applied to file-syncing.”
File transfers are encrypted, with private information never being stored on an external server or in the “cloud.”
“Since Sync is based on P2P and doesn’t require a pit-stop in the cloud, you can transfer files at the maximum speed supported by your network,” BitTorrent said. “BitTorrent Sync is specifically designed to handle large files, so you can sync original, high quality, uncompressed files.”
In the pre-alpha testing that began in January, 20,000 users synced more than 200TB of data. BitTorrent Sync clients can be downloaded now for Windows, Macs, Linux desktops, and Linux-based network-attached storage devices. Mobile support will come later.
ที่มา: BitTorrent Sync creates private, peer-to-peer Dropbox, no cloud required | Ars Technica
ผมเอา btsync ไปลงบน server ปัจจุบัน ใช้แทน dropbox ไปแล้วครับ :015:
อยากรู้จัง peer เยอะแค่ไหนครับ และ peer เร็วหรือเปล่าครับ
peer จะ connect กันแค่ที่มี shared secret เดียวกันครับ ซึ่งก็คือทุกเครื่องที่แชร์ไฟล์ของเราที่ online อยู่ในขณะนั้นครับ อารมณ์เหมือน bittorrent ที่กำลัง seed/leech torrent เดียวกันอยู่
การ sync file ใหญ่ๆ ทำได้เร็วมากกกกกก การ connect peer ทำได้ดีครับ แต่จะมี delay เล็กน้อยประมาณครึ่งถึงหนึ่งนาทีก่อน file ที่ถูกแก้ไขจะ sync กัน
แนะนำให้ลงบน server และหาพวก file manager ผ่านหน้าเว็บมาลงครอบ เราก็จะได้ dropbox เอาไว้ใช้งานโดยเวลาไปที่อื่นก็ยัง access file ผ่านหน้า web ได้ด้วยครับ
อันนี้รีวิวคร่าวๆ http://balll.me/review-bittorrent-sync/
ละเอียดเยี่ยมยอด ขอบคุณครับ :d5f02ecd:
น่าสนครับ :875328cc:
ใช้งานในวงแลน โดยไม่ต่อเน็ตได้มั้ยครับ
