DirectAdmin มีเมนูเปิดให้ User ใช้ Shell แต่ มัน ทำ Jail ไว้มั้ยครับ?
เช่น มี 2 user
user1
user2
user1 สามารถ ใช้คำสั่ง
cat /home/user2/public_html/sql_infomation.php
เพื่อดูไฟล์ของ user2 ได้ อ่ะครับ มี da มี ระบบออกมารองรับตรงนี้ มั้ย หรือมีวิธี ทำ jail ให้พวกนี้อย่างง่ายมั้ยครับ
เบื้องต้นทราบแล้วว่า DA ไม่ได้ทำ Jail Shell มาให้ ผมหาข้อมูลซักพักก็เจอวิธีครับ
http://www.directadmin.com/forum/showthread.php?s=&threadid=2107&perpage=20&highlight=Jail&pagenumber=3
Hi Guys,
Ok, here we go
I’ll classify this as pre-beta… alpha even… I have tested it somewhat, but there are so many areas that this script will touch that we can only assume it won’t be perfect straight out of the gates.
I’ll also ask that all “issues” with it get posted back here and not emailed to us so that we don’t get duplicate support requests piled up in our inbox
Also note that there is no jailing interface for DA as this time, and all jailed users will need to be done manually by running a script for each one (you could actually add it to the user_create_post.sh script, but i’ll let you guys figure that out)
Installation of the jailing scripts and patches:
Code:
cd /usr/local/directadmin/customapache
mkdir jail
cd jail
wget http://files.directadmin.com/services/customapache/jail/build
chmod 755 build
./build update
./build allThat should get the new files, patch apache and build a few programs.
Once that’s all good and ready, I recommend you backup /etc/passwd, /etc/shadow, /etc/group, and /etc/master.passwd (if you have it), just for safety measures
To jail a particular user, first create him through DA, and make sure he has SSH enabled. This will add all required lines to the sshd_config file. Once created and ssh is enabled, you can then setup the jailing environment:
Code:
cd /usr/local/directadmin/customapache/jail
./jail_user.sh usernameThat should setup the environment and also setup the jailed shell.
If you want them to have Jailed CGI, then you need to add some code to their httpd.conf. Go to Admin Panel -> Admin Settings -> Custom httpd configurations -> domain.com (for each of their domains) and add:
Code:
SetEnv JAIL_DIR |HOME|Php (when run as apache) isn’t jailed like cgi is, but with the open_basedir function, it should help tighten things up.
I’ve included nbsmtp as a replacement for sendmail inside the jail which basically just connects to port 25 to send email through the regular exim.
I expect it not to be perfect at this point, but it should be functional at least.
John
พอทำเสร็จแล้ว ถึงขั้นตอน
./jail_user.sh username มันก็ขึ้นว่า
cp: cannot stat `/usr/local/directadmin/customapache/jail/su’: No such file or directory
ทำยังไงดีครับ ?? พี่ๆคนไหนมีประสปการณ์รบกวนแนะนำด้วยคับ
ผมว่าอันตรายเหมือนกันนะครับ ผิด jailshell นี่ครับ
แต่ถ้าจำเป็น ลองดูการตั้งค่า ความปลอดภัยดี ๆ ด้วยครับ ป้องกันไว้ก่อน
[quote author=thaidhost link=topic=16872.msg158076#msg158076 date=1232206259]
