ลองดู error แล้ว บอกว่าอย่างนี้ครับ ไม่ทราบพอมีใครเคยเจอปัญหานี้บ้างหรือเปล่าครับ
[FONT=Menlo][root@cs01 ~]# tail -n 50 /var/lib/mysql/xxxxxxxxx.err[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [ERROR] InnoDB: Could not open or create the system tablespace. If you tried to add new data files to the system tablespace, and it failed here, you should now edit innodb_data_file_path in my.cnf back to what it was, and remove the new ibdata files InnoDB created in this failed attempt. InnoDB only wrote those files full of zeros, but did not yet use them in any way. But be careful: do not remove old data files which contain your precious data![/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [ERROR] Plugin ‘InnoDB’ init function returned error.[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [ERROR] Plugin ‘InnoDB’ registration as a STORAGE ENGINE failed.[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [ERROR] Unknown/unsupported storage engine: InnoDB[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [ERROR] Aborting[/FONT]
[FONT=Menlo]
[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Binlog end[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘partition’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘ARCHIVE’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘BLACKHOLE’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_DATAFILES’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_TABLESPACES’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_FOREIGN_COLS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_FOREIGN’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_FIELDS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_COLUMNS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_INDEXES’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_TABLESTATS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_SYS_TABLES’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_INDEX_TABLE’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_INDEX_CACHE’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_CONFIG’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_BEING_DELETED’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_DELETED’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_FT_DEFAULT_STOPWORD’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_METRICS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_BUFFER_POOL_STATS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_BUFFER_PAGE_LRU’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_BUFFER_PAGE’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMP_PER_INDEX_RESET’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMP_PER_INDEX’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMPMEM_RESET’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMPMEM’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMP_RESET’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_CMP’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_LOCK_WAITS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_LOCKS’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘INNODB_TRX’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘PERFORMANCE_SCHEMA’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘CSV’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘MEMORY’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘MRG_MYISAM’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘MyISAM’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘sha256_password’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘mysql_old_password’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘mysql_native_password’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] Shutting down plugin ‘binlog’[/FONT]
[FONT=Menlo]2015-09-20 16:48:07 32201 [Note] /usr/sbin/mysqld: Shutdown complete[/FONT]
