DirectAdmin 1.50.1 ออกแล้วครับ
06/09/16 Version 1.501
Ability to have backup tar exit code 1 throw error
feature
Brute Force Monitor: Skip User distributed attack User count
feature
letsencrypt_pre.sh and letsencrypt_post.sh
feature
Letsencrypt autorenew from 85 to 60 days
feature
Let’s Encrypt: Ability to select which DNS records to include in the certificate (SKINS)(LANG)
feature
Per-User user.conf override for max_per_email_send_limit
feature
Disable overusage notices if account=OFF
feature
Show Warning if DA has not been restarted since last license update (SKINS)(LANG)
feature
Ability to change ns1/ns2 values without affecting package (LANG)
feature
LetsEncrypt: Don’t require the use of the other CSR fields (SKINS)
bugfix
LetsEncrypt: .well-known directory needs to be 755
bugfix
Changing NS1/NS2 via User Settings causes domain with double dot
bugfix
Domain name change to call dns_write_post.sh on cluster=0
bugfix
FreeBSD: Backup --exclude-file in bsdtar
bugfix
username filtering on CMD_SELECT_USERS
bugfix
direct_imap_backup to no backup imap folder if it doesn’t exist
bugfix
Usage (Meg) quota limit of 4096 caused decimal points
bugfix
global custom tokens accessed wrong files
bugfix
Restore custom apache config at admin level
bugfix
LetsEncrypt: new local challenge pre-test
bugfix
Imap restore not setting mail group on files
อัพเรียบร้อยครับ : D
เวอร์ชั่นนี้รู้สึกว่านานกว่าจะออก อัพไป 3 เครื่อง ยังปกติดีอยู่ครับ
แก้ Let ละ
อัพแล้วครับ
