- Cisco WIC-T1 1 port Serial WAN Interface Card หมดประกันแล้ว ราคา 1400 บาท
The WIC-1T features the Cisco 5-in-1 connector which supports several serial protocols (V.35, X.21, RS-232, RS-449, RS-530) when used with the appropriate transition cable. This facilitates easy configuration and re-configuration as network requirements change without the need to purchase a different serial interface card.
- Cisco Two-port FXS Voice /Fax Interface Card หมดประกันแล้ว ราคา 3200 บาท
This two port Foreign Exchange Station (FXS) voice interface card (VIC) can be used for connecting directly to a standard telephone, fax machine, or similar device, and supplies ring, voltage, and dial tone. The FXS interface is an RJ-11 connector that connects to basic telephone service equipment, key sets, and private branch exchanges (PBXs).
Voice Hardware Compatibility Matrix (Cisco 17xx, 26/36/37xx, VG200, Catalyst 4500/4000, Catalyst 6xxx)
Specification:
- VIC-2FXS= Two-port FXS Voice /Fax Interface Card
- Voice Hardware Compatibility Matrix (Cisco 17xx, 26/36/37xx, VG200, Catalyst 4500/4000, Catalyst 6xxx)
สนใจ PM หรือ ติดต่อที่ paisal.t@gmail.com ครับ
