Black Holes May Not Grow Beyond Certain Limit
xyz writes "Do black holes increase in size indefinitely? According to an analysis by astronomers at Yale and the European Southern Observatory, the maximum size a black hole may reach is only few tens of billion of solar masses. The limit was calculated using an analysis of what may happen to the gas surrounding a black hole which has reached few tens of billions of solar masses. It is thought that black holes of such size heat the surrounding gas to a temperature where the radiation pressure begins blowing outer layers into space."Read more of this story at Slashdot.
