โครงการคุ้ยขยะมาทำของเล่น (1) ตอน kvm
สืบเนื่องจากกระทู้นี้เลยได้ไอเดีย
นึกไม่ออกสมองไม่แล่น เลยไปเบรินสมองกับ ป๋าแบนแฟนเยอะ กับป๋าทอง
ตัวจริงโคตรดูดีแต่หน้าไม่รับลูกค้า ไม่เป็นอะไรปิดไฟก็ไม่เห็นแล้ว
คุ้ยขยะกองแรก
อะไรแว้ในกล่อง HP
Poweredeg 180as
Highlighted Features
The console switches come with a choice of two Server Interface Pods (SIPs) — PS/2 or USB — to fit a variety of server needs. A SIP replaces a bulky KVM (keyboard, video, mouse) cable by converting the keyboard, monitor and mouse signals from a server and driving them up to 15 meters (50 feet) through a single Category 5 (CAT 5) cable. The SIP cable draws its power from the server and has a Keep Alive functionality that is designed to keep the server working properly with or without connectivity to the unit.
The switches enable cross-platform management using the On-Screen Configuration and Activity Reporting (OSCAR®) interface. With the OSCAR interface, administrators can easily configure the switch system and select the different servers. Computers can be identified by unique name, electronic ID (EID) or port number, allowing users to assign unique server names.
An optional accessory to these units is the Dell Port Expansion Module (PEM), which is a passive device that can be mounted next to the railing of the rack. A PEM connects to one system port on the switch and then eight servers. With a PEM connected to each of the eight ports on the 180AS, the total system capacity of a 180AS expands to 64 total servers.
Other highlights include:
Connectivity — features intelligent analog ports
Flash upgradeable — designed for future hardware compatibility
Flexibility — provides access and control of multiple servers from a single screen
Integration — works with wireless KVM (local port extension) and KVM over IP (cascading/tiering)
Scalability — grows with an expanding IT environment
Space-efficient design — occupies 0U in a Dell rack
CAT 5 cabling — reduces cable bulk
Kvm แบบไม่over ip แบบนี้สายเสียซื้อสายแลนมาใช้แทนถูกกว่าแบบทั่วไปเยอะมาก
หัวแบบ VGA port แบบ USB
อีกข้างเป็นแบบ Rj45
ใช้สายแลนธรรมดาก็ได้ครับ
port ต่างๆ
ไปคุ้ยอีกกอง
Aten CN6000
เอามาต่อแบบนี้
หล่อ
สิริรามราคา
Poweredeg a180as 25000 บาท
หัว ต่อserver 3000 บาท ต่อหัว
Aten ถ้าปัจจุบันจะเป็นCN8000 16900 บาท
= 22400
แต่ถ้าไปซื้อ dell รุ่นที่ เป็น over ip 8 port ก็จะราคา 65000 ไม่รวมหัวโมดูล รีโหมดได้2 user
ทีนี้มีหลายตู้ก็มิใช่ปัญหาแต่อย่างใดแถมลากได้ไกลสุดเท้า
ของเล่นเยอะจริงๆๆ
ราคานี้ของใหม่หรือว่ามือ2 ebay อ่ะ
ปล. หัวต่อแพงโคดๆ ถ้าต่อครบ 8 port หมดหลายตัง
ตก 0ไปตัวขอบคุณครับ
อืม เห็นราคาแล้ว ถ้ามีตู้เดียว cn8000 ตัวเดียวจบ
ถ้ามี 2 ตู้ขึ้นไปก็น่าทำเพราะต่อจอใช้สาย lan เดินข้ามตู้ทิ้งไว้ได้เลย
ปิดไฟทำไมครับพี่ป๊อป 55+
คิดจะ ตามขั้นตอน
อาบน้ำ หรือ อ่าง
คิด…
ชักอาวุธออกมา
ฟันแม่มเลย
หลังจากเสร็จและเขาก็ทำหน้าแบบ
หลังจากจ่ายเสร็จก็…
ลัลล้าต่อไป
พอถึงบ้าน
สภาพก็จะเป็นแบบนี้
ใช่มะครับพี่ตั้ม
แล้วสั่งให้ kvm ไม่ overip สลับพอร์ตยังไงครับ
ลืมดุ กระทุ้ how to ขอโทดงับ555
กดคีรืลัดอีกทีครับ
กดจาก คีย์บอร์ด ได้เลยเหรอ แหล่มเป็ด
ป๊อบ กล่องไม่ใช้หรือไม่ขายขอนะ จะเอามาใช้ขนยา 5555
ตัวนี้เจ๋งกว่า ตัวเดียวคุมทั้งตู้เลย
Altusen Cat 5 Over IP KVM 32 Server
หล่อเลยครับ
ราคาหละ T_T
ตัวนี้เลย
[color=#2B2B2B][font=Arial, sans-serif][size=2]KN4140v :: 40-Port KVM Over the NET™ - 1 local / 4 remote user access
KN4140v คือ KVM Over IP ที่สามารถควบคุมดูแลเซิร์ฟเวอร์ 40 เครื่องได้จาก 1 local console และ 4 remote user access ผ่านเครือข่าย LAN/Internet ได้พร้อมกัน
[/size][/font][/color]
ราคาปกติ: 184,000.00 บาท
ราคาลดพิเศษ: 180,000.00 บาท (192,600.00 บาท รวมภาษีแล้ว)
ที่มาครับ http://www.pantiponline.com/Altusen-Cat-5-Over-IP-KVM-32-Server.html
