WHMCS 6.3 Released
มีใครลองแล้วบ้างเอ่ย:baa60776:[B]
Release Note:[/B]
- Markdown Support - WHMCS now supports Markdown formatting in client ticket creation & reply, admin ticket reply, admin ticket note generation and client notes. In addition to supporting Markdown, a new text editor has been introduced that gives users an easy-to-use interface for adding text styling such as bold, italicize, lists, code snippets, quotes and more. For more information, see the Markdown Editor documentation.
- Easy Translation - This feature enables admins to translate product names, product descriptions, product groups names, headlines and taglines, custom field names, and custom field descriptions in accordance to language files configured in WHMCS. For further details please click here.
- Email Verification - This feature allows you to validate and ensure that the email address a client registers with is valid and their own. When enabled, upon creation of a new client account or change of email address, an email is sent to the email address provided asking the user to confirm that they intended to register or make the change of email address. For more information, please see Client Email Verification
- Drag & Drop Sorting - Products and product groups can now be sorted more quickly and easily via a drag and drop interface. It is important to note however that products may only be moved within their existing product group. Full documentation can be found here.
- Ticket Watchers - Admin users can now elect to Watch Tickets which provides them with email notifications any time there is ticket activity. For more information, please refer to the [[Support_Tickets#Ticket_Watchers|Ticket Watchers] ] guide.
- Ticket Notifications - The format of admin user support ticket notifications has been updated. A new email template will be created as part of this update. There have also been some refinements to when notifications are sent. For a complete list, please refer to Ticket Notifications.
- In-line Ticket Notes - Ticket notes will now be displayed in-line alongside ticket replies. This is designed to make it easier to follow the chronological order of events in a support ticket. If you do not see this after upgrading, please check you have updated your active admin area template files.
- Admin Area Ticket UI - The ticket reply and add note admin UI’s have been re-designed and additional options added to allow setting ticket options such as department, assignment and priority at the same time as posting a reply. If you do not see these updates after upgrading, please check you have updated your active admin area template files.
- In-line Image Attachment Previews - Image attachments can now be viewed in-line within the ticket interface without having to download them. The option to download remains via a download link shown below the image thumbnail.
- Improved Ticket Filters - The admin area ticket search options have been expanded to allow filtering by Priority, as well as multiple criteria concurrently.
- Merged Tickets Behaviour Change - Merged tickets are now retained and will continue to appear in search results post merge. Links to merged tickets both within the interfaces and via email will redirect admins to the resulting active merged ticket. Submitting a reply to a merged ticket via email will also correctly and automatically redirect the reply to the resulting merged ticket.
- Client Password Hashing - Client password hashes are now created using the Bcrypt cryptographic algorithm. Previously stored Client and Sub-Account hashes will be updated on their first successful login following the deployment of this update.
- Email Design Update - This update provides a new default email layout that is designed to be cross platform compatible, mobile friendly and fully responsive. The changes for this will only be automatically applied should you not have customised the Global Email Header and Footer design in Setup > General Settings > Mail. If you have customised these and wish to apply the new styling manually, please refer to Email Styling.
- Income by Product Change - Version 6.3 extends the Income By Product report to include both setup and recurring fees into the report. Previous versions of this report only reported setup fees.
- Support Tickets Index Optimization - WHMCS 6.3.0 includes a new optimization to an index used for tickets. Depending on the size of the table and the performance of the database server, this may extend how long the upgrade takes. If you are unable to finish the upgrade in a single run it is recommend to remove the file resources/sql/upgrade630alpha1.sql and run each of the statements manually via a mysql client and then try upgrading again. This change will result in improved loading times for WHMCS installations with large amounts of ticket data.
Release Notes
Changelog
Download
