Plesk ออก 8.4 แล้วนะครับ
เตรียมเสียเงินกันได้เลย
http://www.parallels.com/en/products/plesk/new/
Feature ใหม่
Top features in Plesk 8.4Categories in Application Vault – Browse applications by certain categories - like “Web/Blog” or "Collaboration/Portals” within the Application Vault.
DomainKeys support – Provide additional AntiSPAM protection with DomainKeys technology – currently used by Gmail, Yahoo, Verisign, and others.
4PSA VoipNow integration - Plesk 8.4 provides integration with 4PSA VoipNow solution.
Database users prefix – Include a prefix for all database users within a certain domain for increased security and easy searching.
Import/Export Database Backup - Plesk allows you to back up and subsequently restore your databases on a per-domain basis.
New Plesk events - New API events generated upon domain and client template creation, update or removal are available.
Ability to block domain creation in foreign DNS zone - Provide customers with increased security level by forbidding clients to create domains that are subdomains of another domain. This prevents that such unauthorized subdomains can be used for spam (and thus original domain holder will be blamed), phishing and exploiting XSS vulnerabilities.
Extended branding options - Plesk allows you to change browser window title though Plesk GUI.
Application Packaging Standard (APS) CGI support - Complete support of APS CGI applications.
ใครใช้ version เก่าก็ upgrade กันได้นะครับ
Version เก่ายังคง upgrade ได้นะครับ
แต่สำหรับลลูกค้าเก่าที่หมด SUS ไป เด๊ยวคาดว่าจะมี promotion ต่อในราคาพิเศษครับ
ติดตามแล้วกันครับ
