[root@server /]# env LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
Unknown SNMP var ssCpuRawUser.0
at /usr/bin/mrtg line 2243
2010-07-22 10:14:12: WARNING: Expected a number but got ‘0:58:51’
2010-07-22 10:14:12: WARNING: Expected a number but got ‘server.localhost.com’
Unknown SNMP var ssCpuRawSystem.0
Unknown SNMP var ssCpuRawNice.0
Unknown SNMP var memAvailReal.0
Unknown SNMP var memTotalReal.0
2010-07-22 10:14:12: WARNING: Problem with External get ‘/var/www/mrtg/php.load.php’:
Expected a Number for ‘in’ but got ‘#!/usr/local/bin/php -q’
/usr/bin/rateup: /usr/local/lib/libpng12.so.0: no version information available (required by /usr/lib64/libgd.so.2)
2010-07-22 10:14:12: ERROR: Target[public.cpusum][IN] ‘( $target->[1]{$mode} + $target->[2]{$mode} + $target->[3]{$mode} )’ (warn): Use of uninitialized value in addition (+) at (eval 21) line 1.
2010-07-22 10:14:12: ERROR: Target[public.cpusum][OUT] ‘( $target->[1]{$mode} + $target->[2]{$mode} + $target->[3]{$mode} )’ (warn): Use of uninitialized value in addition (+) at (eval 22) line 1.
2010-07-22 10:14:12: ERROR: Target[public.memory][IN] ’ $target->[4]{$mode} ’ did not eval into defined data
2010-07-22 10:14:12: ERROR: Target[public.memory][OUT] ’ $target->[4]{$mode} ’ did not eval into defined data
2010-07-22 10:14:12: ERROR: Target[public.load][IN] ’ $target->[7]{$mode} ’ did not eval into defined data
แต่… ติดปัญหาที่แก้ไม่ได้สักที่ Free Ram กับ Active CPU Load % มีวิธีไหมครับ
