มันจะขยันไปถึงไหน… :189bbdde:
[h=3]ChangeLog[/h][h=3]Version: 3.7.0 Date: 07-13-2012[/h][h=4]Added/Changed[/h]Added: Ticket Macros: You can perform multiple ticket actions at once - add reply, change status, assign tag & more - with one click.
Added: Ticket Bulk Actions: Select multiple tickets and update them at once - apply macro, change ticket details, apply tags, assign staff member.
Added: Ticket Assign: Staff member can now be assigned to ticket & be directly responsible for it.
Added: Ticket SLA/Escalations: Ticket department now can offer automated SLA/Escalations & Ticket overdues.
Added: Ticket Filters: Advanced ticket filtering & automation capabilities - you can define pre and post-import filters & choose how HostBill should react on them.
Added: Ticket Priority Select in clientarea: If enabled in department settings, client can now define ticket priority during its submission.
Added: Email Templates: Staff members can now define multi-lingual email templates without using transation tags (1 template=1 language)
Added: New Order Page: 3 Steps Slider: Order Page templates | HostBill | Billing & Automation Software for WebHosts
Added: Built-in mobile notifications: Your clients and staff members can receive customizable notifications from your HostBill on mobile device
Added: Notification Module: Twilio SMS notification module
Added: Notification Module: Clickatell SMS notification module
Added: Notification Module: iPhone Prowl push notifications module
Added: Notification Module: Notify My Android push notifications module
Added: Clientarea: Clients can now search their domains in client interface (“nextgen” theme)
Added: Module: WorldPay FuturePay - new payment gateway with automated recurring billing
Added: Plugin: One Time Passwords - Two-factor authentication in your adminarea using Time-Based One Time Passwords generated by your mobile device.
Added: Module: OnApp: New client function - Reverse DNS - clients can now manage their rDNS records (requires IPAM plugin) Preview
Added: Module: OnApp: Its now possible to set monthly data transfer limit
Added: Module: OnApp: Clients now have ability to define tags for each virtual machine Preview
Added: Module: Cloudstack: Selection of networking type (Basic/Advanced) during package configuration
Added: Module: Cloudstack: Support for advanced network configuration.
Added: Module: Cloudstack: Multiple provisioning options for advanced networking (assigning current networks for each client VM available).
Added: Module: Cloudstack: Console is now available in clientarea
Added: Module: Cloudstack: New client function - Reverse DNS - clients can now manage their rDNS records (requires IPAM plugin)
Added: Module: Citrix Xenserver : New product configuration - ability to use resource sliders for memory/ disk/ cpu, configure template prices.
Added: Module: Citrix Xenserver : Clients now have ability to automatically upgrade to higher packages / change single resources using sliders
Added: Module: Switch SNMP: Support for Cisco Catalyst 2950 series
Added: Bandwidth Billing: Ability to bill quarterly
Added: DevKit: New hooks: before_domaintransfer, before_domainrenew, before_accountsuspend, before_accountcreate, before_accountterminate, before_accountunsuspend, after_ticketescalate, after_ticketoverdue
[h=4]Bugs Fixed[/h]0000080: [module] OnApp: Unable to add new network from client interface due to “Network Join ID” error
0000066: [adminarea] Task List: Auto provision paid accounts task is not enabled by default
0000079: [general] Invoices: Adding transaction to invoice with Decimal places set to 0 fails to mark invoice as paid
0000078: [module] OnApp: Usage graphs show incorrect data for onapp 2.3.2
0000077: [module] OnApp CDN: Metered usage is incorrectly calculated
0000076: [module] OnApp CDN: Clientarea shows available rather than assigned locations to Edge Group
0000075: [adminarea] Tickets: Automated draft save updates draft with wrong id, overwriting previous replies
0000074: [cart] Forms & Subproducts: Free subproduct have applied forms configuration from main package on invoice
0000073: [general] Install: Installation requires chmod 640 for config.php, which will fail on non-su_php php
0000055: [module] ResellerClub shows wrong user & password
0000072: [security] Potential XSS security threat during new order placed trough clientarea on various orderpages
0000050: [module] TheSSL store error when creating order page
0000054: [cart] Onestep checkout slider orderpage duplicating custom form components
0000053: [clientarea] Simple hosting template for nextgen
0000048: [module] OpenSRS integration - module no longer shows login credentials in recent versions
0000052: [cart] Changing packages from the same order page removes selected domain config
0000051: [module] OnApp DNS sets wrong customer email in default SOA record
0000071: [clientarea] DNS Management for domains with registered external DNS management does not link to fully-featured manager
0000070: [clientarea] DNS Management: Potential security issue in client management panel for dns actions
0000068: [clientarea] Cloud control panels: pricing options dissapear when trying to upgrade (javascript error)
0000067: [adminarea] Forms: Its not possible to set pricing for Form items if product is using Bandwidth billing
0000008: [clientarea] SSL order page not displaying subproduct
0000049: [adminarea] Check domain for tld .lv dont work
0000006: [module] Unable to unsuspend an account in Cpanel
0000065: [clientarea] Upgrades: Products with sliders & default values are upgraded with wrong charge/recurring price
0000046: [clientarea] Product Download Access
0000064: [module] OnApp: Paid OS templates (windows) can be used without paid invoice
0000063: [module] OnApp: Email already exists error when attempting to create new vms without modified prefix
0000041: [cart] Bootstrap Sliders order page does not work with old Default template
0000038: [module] Created admins can’t view assigned tickets from External ticket
0000039: [module] No information about pre requirements for reinstalling OS on VPS.net accounts
0000037: [clientarea] Upgrading SolusVM accounts does not work , also language translation displays incorrect.
0000022: [general] Changes in before due date invoice generation interval take effect only after new invoice is generated
0000020: [general] HostBill should not auth against the SMTP server when the credentials are left blank.
0000017: [adminarea] Cancellation request link in adminarea home leads to accounts list
0000011: [clientarea] Twitter plugin not working for unbranded license users
0000009: [clientarea] Knowledgebase’s URL rewriting fails for non ascii characters
0000010: [module] Renewing domain faild but expiry date was extended ( Enom )
0000005: [module] Nominet domain registrar error for .co.uk domains
0000004: [general] Automatically Cancelling pending orders
0000062: [module] PayPal: In case of doubled callback from PPal, HostBill doubled transaction
0000061: [module] cPanel HostBill update tool - unable to detect version error
0000059: [clientarea] Client is able to generate bulk invoice out of invoices not enabled to him yet
0000034: [module] OnApp CDN: Test connection issue on OnApp with no HV
0000047: [module] Xenserver: Form elements (sliders) & os tpl are not applied to final VM configuration
0000033: [module] Cloudstack: Usage tab in clientarea not working properly
0000032: [api] getAccountDetails API call not working
0000031: [module] Cloudstack: VM Actions show unavailable sections (like console)
0000030: [module] Cloudstack: Exception when visiting edit VM screen
0000029: [module] Cloudstack: GUI issue on nextgen theme in firewall configuration screen
0000028: [module] Cloudstack: Can’t specify network Ids in Basic zone error while creating VM
0000026: [clientarea] DNS Management doesnt work for domains not linked in external dns manager
0000025: [module] OnApp: Clients are able to view other customers custom OS templates (not able to use though)
0000024: [module] DNS Management client function does not show in adminarea
0000018: [adminarea] Accepting cancellation from cancelation list not working
0000023: [clientarea] Main product configuration fields are applied to sub products as well
0000016: [adminarea] Placing new order for one-time billed product result in setting free/no billing cycle
0000019: [module] Inaccurate description for transactions made trough Google Checkout may lead to account suspension
0000015: [module] OnApp CDN: Module do not provide ability to create username prefix
0000014: [module] OnApp: Client can provide non-permitted chars into hostname field
0000007: [module] OnApp: Using username prefix cause email issue when generating additional accounts
0000013: [adminarea] Creating new order from client details tab do not assign client
0000012: [adminarea] Exception when converting order draft to order with free item
