DirectAdmin 1.41 ออกแล้วครับ
รายละเอียดตามนี้ครับ
[TABLE=“class: list, width: 70%”]
[TR]
[TD=“class: listwrap”]MAILTO for cronjobs (SKINS)[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]CMD_LOGIN_KEYS to Reseller/User Packages (SKINS) ** Manditory Skin Changes **[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]CMD_ADDITIONAL_DOMAINS to list multi-ips[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]ssl_ignore_when_local[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]DNS Admin column for local mail[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]AJAX (SKINS) (BETA)[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Removed NameVirtualHost from ips.conf if Apache 2.4 is used[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Ability to exclude DB data from backup, but include DB Settings (SKINS)[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Ability to reset today’s email usage count to allow more sends[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]FileManager icons upgraded and set to transparent png (SKINS)[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Added |?HEADER| support to lost_password_email.txt [/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Ability to suppress BFM messages[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]user_restore_fail_post.sh[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Display time of last DA restart (SKINS)[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]public_html_link_set_pre.sh and public_html_link_set_post.sh[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Suspend date[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]MD5sum on services.tar.gz[/TD]
[TD][feature][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]encode usernames brute_user.data[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]remove IP with IPv6[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]dovecot 2.1.0 logging change for BFM[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]internal mimtypes.txt wasn’t being used[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]ssl_port is ignored when running in debug mode[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]change_username.sh to check max_username_length[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Changing password when quotas are full can break ~/.shadow[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]SIGTERM not killing all child processes if numservers>20[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]anonymous ftp doesn’t work with secure_access_group[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Add timestamp hour offset for FileManager[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]pureftpd not in brute_filter.list[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Backup to allow tar exit code 256 (–ignore-failed-read)[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]security: encoding of domain output on CMD_DOMAIN[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]Reset count on IP in BFM during unblock[/TD]
[TD][bugfix][/TD]
[/TR]
[TR]
[TD=“class: listwrap”]subdomain_owner_check: Allow sub.sub.domain.com if sub.domain.com is already in list[/TD]
[TD][bugfix][/TD]
[/TR]
[/TABLE]
ขอบคุณมากครับ
เดี๋ยวลองอัพดึกๆ คืนนี้ครับ
เดี๋ยวมีบั๊กอะไรเอ๋อๆให้อัพกันใหม่อีกหรือเปล่า :70bff581:
ไว้ต้องลองบ้างและครับ
รอบนี้รอนานเลย
ดิฉันรีบอัพทันทีเลย เพราะรอบนี้มี feature ดีๆ หลายอันที่ชอบมากๆ เช่น
  1. DNS Admin column for local mail – ตอนนี้มองเห็นชัดเลย สมัยก่อนดูยากมาก ลายตาสุดๆ
  2. Ability to reset today’s email usage count to allow more sends – อันนี้สมัยก่อนเวลารีเซท ต้องใช้วิธีที่อาจารย์แมนสอนมา ตอนนี้สบายเลย กดปุ่มเดียว
  3. Ability to suppress BFM messages --อันนี้คิดว่า หลายๆ ท่านคงรอคอยเช่นกัน ในที่สุด DA ก็จัดให้ :slight_smile:
features น่าสนใจมากๆ
แต่รอดูก่อนดีกว่า น่าจะออก fix ตามมาติดๆเหมือนเวอร์ชั่นก่อนๆ
:026:
อัพเดทละครับ :015:
ขอบคุณครับ ใครอัพแล้วมาบอกด้วยนะครับ
อัพเสร็จแล้วครับ ยังไม่เจอปัญหา เพราะไม่ได้ลองเล่นดู
[COLOR=#0000cd]ใช้มา 2 วันแล้วดีมากๆ ไม่มีปัญหาอะไรค่ะ และชอบมาก ตรงที่เขาปรับปรุงเรื่อง Brute Force Monitor และ script block ip อัตโนมัติของเขาค่ะ
[/COLOR]ตอนนี้ script block ip อัตโนมัติของ DA เขาปรับปรุงใหม่ดีค่ะ ก่อนนี้มันฟ้องอย่างเดียวไม่ยอมบล็อกให้ แค่ให้ปุ่ม block มาให้กดมือเอา หากอยาก block อัตโนมัติ ต้องแก้ script ให้ไปดึง csf มาบล็อกแทน ตอนนี้ไม่ต้องแก้ script แล้วค่ะ เพราะ block_ip.sh ของเขามันปรับปรุงให้บล็อกอัตโนมัติด้วย iptable ได้เลยโดยตรง พร้อมอีเมลแจ้งบอกว่าบล็อกใครไปบ้าง
[COLOR=#0000cd]แต่อีเมลแจ้งการบล็อก ip ของ DA มันยังไม่ฉลาดเท่าอีเมลของ csf[/COLOR] [COLOR=#0000cd]ค่ะ
[/COLOR]…
[COLOR=#800080]ตัวอย่างอีเมลของ csf บอก ip บอกประเทศ บอก user ที่พยายามล็อกอิน ทำให้เราทราบว่า หากเป็นไทย ล็อกอินด้วย user ปกติ คือลูกค้าเราเข้าผิดนั่นเอง เราก็ปลด unblock ให้ได้เลย แต่ถ้าเป็น ip ต่างประเทศ แล้วล็อกอินด้วย user แบบสุ่ม นี้แฮกเกอร์แน่ๆ ปล่อยบล็อกยาวไปเลย [/COLOR][COLOR=#0000cd]ส่วนอีเมลของ DA ไม่บอก user ที่เข้าผิด เลยทำให้เดาไม่ได้ว่า เป็นลูกค้าเราเองเข้าผิด หรือ แฮกเกอร์พยายามแฮกกันแน่
[/COLOR]
เปรียบเทียบอีเมลแจ้งของ csf กับ อีเมลของ DA … ค่ะ…
[COLOR=#800080]อันนี้อีเมลของ CSF ค่ะ…
lfd on server3: blocked 62.61.152.4 (DK/Denmark/mx-02.danskkabeltv.dk)
Time: Tue Jun 12 07:50:04 2012 +0700
IP: 62.61.152.4 (DK/Denmark/mx-02.danskkabeltv.dk)
Failures: 4 (smtpauth)
Interval: 300 seconds
Blocked: Permanent Block
Log entries:
> 2012-06-12 07:49:48 login authenticator failed for mx-02.danskkabeltv.dk (localhost) [62.61.152.4]: 535 Incorrect authentication data [/COLOR]COLOR=#ff0000
[/COLOR][COLOR=#800080]> 2012-06-12 07:49:52 login authenticator failed for mx-02.danskkabeltv.dk (localhost) [62.61.152.4]: 535 Incorrect authentication data [/COLOR]COLOR=#ff0000[/COLOR][COLOR=#0000cd]
[/COLOR][COLOR=#800080]> 2012-06-12 07:49:57 login authenticator failed for mx-02.danskkabeltv.dk (localhost) [62.61.152.4]: 535 Incorrect authentication data [/COLOR]COLOR=#ff0000
[/COLOR][COLOR=#800080]> 2012-06-12 07:50:01 login authenticator failed for mx-02.danskkabeltv.dk (localhost) [62.61.152.4]: 535 Incorrect authentication data [/COLOR]COLOR=#ff0000
[/COLOR]
[COLOR=#0000cd]ส่วนด้านล่างนี้ อีเมลของ DA ให้ข้อมูลมากเพียบ [/COLOR][COLOR=#ff0000]แต่สิ่งที่อยากรู้กับไม่บอกให้รู้[/COLOR][COLOR=#0000cd]เหมือนของ csf ด้านบน…
server3: blocked 62.61.152.4 for 4 failed attempts
IP 62.61.152.4 has been blocked for making 4 failed login attempts
exim2=4&first_entry=1339462202&last_entry=1339462202&last_notify=1339462202
; <<>> DiG 9.3.4-P1 <<>> -x 62.61.152.4
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 49891
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;4.152.61.62.in-addr.arpa. IN PTR
;; ANSWER SECTION:
4.152.61.62.in-addr.arpa. 782 IN PTR mx-02.danskkabeltv.dk.
;; Query time: 0 msec
;; SERVER: 203.150.213.1#53(203.150.213.1)
;; WHEN: Tue Jun 12 07:50:02 2012
;; MSG SIZE rcvd: 77
[/COLOR][COLOR=#800080]…แต่โดยรวมแล้ว DA verion 1.41.0 นี้พัฒนาดีขึ้นมากหลายอันค่ะ ยกนิ้วให้ค่ะ :d5f02ecd:
[/COLOR]
หลายวันผ่านมา ไม่เห็นมีใครแจ้งว่ามีปัญหา เมื่อคืนท่องนะโม 3 จบ เข้า ssh สำรอง update.tar.gz ตัวเก่าไว้ กลับมาหน้า DA จิ้ม update รอด้วยความระทึก ซักครู่ผ่านไป เย้ สำเร็จไม่มี error ทีนี้ก็รอดูผลครับ :slight_smile:
ผมอัพไปแล้วเหมือนกันครับ ไม่พบปัญหาเหมือนกัน มาช่วยคอนเฟริมครับ
แต่ถ้าเราเจอปัญหาแล้ว backup เจ้าไฟล์ update.tar.gz ของ directadmin ไว้แบบที่พี่ ICOM บอกข้างบน
เราจะ Restore version เก่าให้กลับมาเป็นเหมือนเดิมได้ยังไงเหรอครับ
rename ตัวที่เรา backup กลับมาเป็น update.tar.gz แล้วก็
cd /usr/local/directadmin
tar xvzf update.tar.gz
./directadmin p
cd scripts
./update.sh
service directadmin restart
จาก หลายท่านที่ชี้แนะผมไว้เมื่อหลายปีก่อนที่เคยมีปัญหา ผม save เก็บไว้แต่ยังไม่ได้ลองใช้ :slight_smile:
ขอ save เก็บไว้บ้างครับพี่
ขอบคุณมากครับ
