At this place the current query includes more than 300 dump lines. That can happen if your dump file was created by some tool which doesn’t place a semicolon followed by a linebreak at the end of each query, or if your dump contains extended inserts or very long procedure definitions. Please read the BigDump usage notes for more infos. Ask for our support services in order to handle dump files containing extended inserts.
At this place the current query includes more than 3000 dump lines. That can happen if your dump file was created by some tool which doesn’t place a semicolon followed by a linebreak at the end of each query, or if your dump contains extended inserts or very long procedure definitions. Please read the BigDump usage notes for more infos. Ask for our support services in order to handle dump files containing extended inserts.
